95LT1Z28
09-15-2004, 05:30 PM
I just bought a '96 Z with Koni fully adjustable shocks. Where do I make adjustments on these shocks??? I have a round knob that the previous owner gave me to adjust it, but where does it go? Thanks!
Jeff
Jeff
Where is the adjustment "screw" for Koni adjustable shocks???95LT1Z28 09-15-2004, 05:30 PM I just bought a '96 Z with Koni fully adjustable shocks. Where do I make adjustments on these shocks??? I have a round knob that the previous owner gave me to adjust it, but where does it go? Thanks! Jeff agrsiv95 09-15-2004, 05:47 PM The knob is for the rear shocks, you have to pull the carpet up and remove the foam caps and the adjustment is the top of the shock post. The fronts are a little tricky, you need a long pick to get at the knob which is just under the top of the tube. The adjuster has 6 or 8 holes which you turn with the pick to adjust them. Hope this helps J Z28barnett 09-16-2004, 08:48 PM http://www.1le.net/ O-taka 09-17-2004, 06:15 PM yeah, the carpet should have been cut in the rear for the rear adj (fold down seat) for the fronts, i just got several sizes of round wire cotter pins from home depot, found a good size and bent it to adj the fronts. gotta lift the car though to access it thru the springs | ||
