what times will I run
balerjoe
09-14-2004, 04:07 PM
I own a 69 camaro w/427 .040 over with 236 246 dur@50 .540 .540 lift cam
semi open semi closed heads hooker ceramic headers, 3inch exhaust mighty demon 750 carb weiland single plane intake msd ignition
3000 stall converter, th400 3:55 gears . 10.5 compression. What kind of times can I look to be running
camcojb
09-14-2004, 10:08 PM
Mid to upper 12's with traction. Possibly low 12's if you really sort it out.
Jody
novacaine_68
09-16-2004, 10:27 PM
It depends on how good those heads are. What are semi-open, semi-closed heads :confused:? Its either one or the other as far as I know, maybe I missunderstood you. If you have aftermarket heads or ported stock heads, and get traction...I'd say high 11's on a great day. low to mid 12's on an average to bad day. Like I said all depends on traction, suspension, and how good that engines breathing.
You could have an 11 sec. engine, but a 13 sec. car, know what I'm sayin' ;) .
