Oil return, oil level sender hole
Alvin@pcmforless.com
09-13-2004, 09:28 PM
has anyone ever thought about using the oil level sender hole for a oil return? Its relatively high in the pan if i remeber right... I haven't checked exactly what the threads are but i would imagine they are NPT.
I'm just not excited about punching/tapping my oil pan.. I would much rather drill/weld a fitting in. but thats out of the question with the motor in the car.
carnutz
09-13-2004, 09:32 PM
So jack the engine up, and pull the pan, do whatever you need to and put it back.
Oh ya and throw a new pump and bearings at it if they are abused....
Brady
09-13-2004, 10:01 PM
I think the low level sender is equivalent to about 2 quarts low.. lower than you would want to run it, IMHO. I don't have the desire to look it up, but in my old twin turbo pics I have some pictures of my drain back dilemma.. http://teamprickracing.com/twinturbo
Brady
09-13-2004, 10:15 PM
http://teamprickracing.com/twinturbo/Installation3/
http://teamprickracing.com/twinturbo/Installation5/
I looked around on my website and found a couple pages that may be of some help, if not- just ignore me.
09-13-2004, 10:21 PM
ah, I see that is too low.. I was thinking it was higher than that.
I know all about drain back, I built a twin turbo kit for a SN95 and we had some drain back issues.
Crap, I wish I had welded a fitting in there "in case" when the motor out last year.
oh well, I'll just punch it and tap it. Would have been a cool idea if tha twas higher
ss#1230
09-14-2004, 03:22 AM
hey brady, how was it dropping the motor and the front suspension out the bottom like that?
looks fairly simple that way.
im thinking about pulling the motor myself when it comes time to do a rebuild.
flusz28
09-14-2004, 08:18 AM
its very easy to punch and tap a hole nothing to worry bout
Sean94Z
09-14-2004, 09:00 AM
It's so easy doing it that way. Much nicer to assemble the entire motor and trans before putting it back in the car. Just take your time putting it back in, and lower the car down to the motor, dont lift the motor to the car. Same thing when you take it out, lower the motor, and then raise the car off of it.
--Sean
Gearhead6s
09-14-2004, 11:33 PM
i ran my return line to the low oil level sender hole. why would it be too low. i have a turbo tech kit and just run the return line down through the k member to the pan. when i go to rebuild this winter i won't run it that way again but it works fine now. why do you say its too low?
