Bushings
jcamaro30th
09-12-2004, 11:59 PM
Okay guy.. i have done searches after searches, cant come up with anything helpful... so i'm asking all you for your help?????
this is what i need to replace on my car (97 30th annv. conv. z28) all the rear bushings,,,, the bushings on the LCA's (just the bushings) endlinks, and i want to go with the poly bushings...
My questions is what's the best website to get them from?????
Ucantcme57
09-13-2004, 02:57 PM
go to http://www.p-s-t.com/
Look at their Poly-graphite bushings.. they don't sqeak, and are alot more rigid than reg. poly bushings they resist body roll and other deflections.. I have them and would recommend them to anybody... PST sells front end kits, rear end kits, and even single units..
jcamaro30th
09-13-2004, 08:42 PM
thank you very much Ucantcme57 !!!!!
Steve in Seattle
09-13-2004, 08:56 PM
don't use poly in your LCA's. bad idea.
Go with QA1 rod-ends in your PHR (need to replace the whole unit, but it's failry cheap)... quiet as a mouse in daily driving.
Poly sway bar endlinks and bushings are a great idea... as is a poly trannsmission mount (although that one can be a bit noisey). :)
lt4 fd
02-25-2005, 11:38 PM
Wait which lca's should you not use poly in because it seems to be working great in my rear lca's...? Also what part of the tie rod end has poly in it?
