"White Knight"
09-09-2004, 12:00 PM
I was thinking the other day on your guys' nitrous set-ups, the button you push to spray it is one of those switches that stays on till you push it again correct? so when you hit it it stays on? then when you get to the end of the track the WOT switch kicks off the nitrous when you let off the gas? Or are some of you using buttons you hold down and let off when you don't want it.
LPEdave
09-09-2004, 01:19 PM
To my knowledge, most anyone using a "button" that they press is using one that they have to hold to keep the nitrous spraying, not one that they press once to start it, then again to shut it off.
Dave
rpm4lalo
09-09-2004, 03:16 PM
I use a pushbutton and it is momentary. if I don't keep it depressed the nitrous will turn off.
Now I also have a window switch, microswitch and main nitrous arm, but if the button is not held it, it will not spray.
"White Knight"
09-10-2004, 02:45 PM
alright that's what i was wondering.
