2 bar map sensor -will it work?
flusz28
09-09-2004, 10:17 AM
i ahve a stock pcm that is tuned and i'm using a 2 bar map sensor. will my car beable to read the 2 bar map? i'm going to be running 8psi
Highlander
09-09-2004, 01:07 PM
you willbe able. you will have to rearrange the whole cal though...
Roadie
09-09-2004, 03:40 PM
2 bar map sensor will work, but you lose resolution for everything below boost levels. It probably won't affect too much as long as you are good with tweaking your tune.
I'm going to migrate to a 2 bar map sensor when I install the delteq since the 6BTM will not work with the opti replacements. WIth the help and files of a few people on here, I created the this tune as my baseline.
http://www.lt1.org/other/2barblower.bin
I haven't run this tune yet, and I wouldn't trust it completely because I haven't had a chance to shake it down. If you do use this as a starting point for your tune, let me know if you have to make any big corrections to get it to work right.
davepl
09-09-2004, 05:58 PM
Not sure what good a 2 bar map will do you, since you'll hit the MAF limit long before it becomes an issue anyway...
Highlander
09-09-2004, 06:55 PM
You can always tune around the maf limitation, so that shouldn't be a problem.
flusz28
09-09-2004, 09:46 PM
so basically don't use the two bar sensor?? thanks guys
Highlander
09-09-2004, 09:47 PM
Yes Use It
flusz28
09-09-2004, 09:51 PM
Ion tuned the car for everything except for the 2 bar, since i got it afterwards. he has it setup for the boost i'm running. still need to get a dyno tune then have the computer sent back to him.
davepl
09-09-2004, 10:17 PM
The MAP sensor isn't used for much on a MAF car, so its pretty pointless.
Roadie
09-09-2004, 11:04 PM
There's obvious advantages to having a boost-aware PCM, otherwise all the turbo and supercharged cars coming from the factory would have a 1 bar map sensor and blindly adjust timing and fuel when it hits boost.
the main reason why I want to do it is that a boost-aware PCM has accurate spark control based on boost level, not on a worst case scenario -- this adds the ability to swap pulleys without a retune (as long as boost fuelling is also covered). I could use the MSD box if I wanted to stick with the opti, but I want to replace it with something that's maintenance free.
flusz28
09-09-2004, 11:22 PM
i have the msd btm unit on my car
flusz28
09-09-2004, 11:24 PM
my computer wouldn't let me view you link for the tun baseline...
Highlander
09-10-2004, 01:12 AM
No that is not correct really..
The map is extremely important for timing and VE and open loop fueling...
The maf will not negate everything....
Roadie... when you change the boost it is often times better to re-tune. there is nothing like a tune for all conditions... and since you don't have a MAP PE table, well... you will need to deal with your fueling again.
davepl
09-10-2004, 01:19 AM
Actually, you're not correct either! The MAP is indeed important for timing, which I neglected. But its not used for open loop fueling, at least on the LT1.
Now, if your MAF fails and you fall into speed density mode, its used. But that's not an open/closed loop issue.
Highlander
09-10-2004, 01:42 AM
Sorry i meant speed density... not open loop, as VE goes in par with Speed density and not open loop.
Roadie
09-10-2004, 10:50 AM
I agree on the fuelling bit, but that's why I said "as long as boost fuelling is also covered". It's a lot quicker for me to have a good baseline and tweak the superfueller on the dyno than it is to retune a few times on the dyno.
If money were no object, I'd not worry about dyno time costing $$, ditch the stock pcm and go with FAST or DFI, and probably have a whole lot more power. :D
Highlander
09-10-2004, 11:15 AM
You know... even if $ where no object, i would still keep the stock pcm.
arnie
09-12-2004, 07:40 PM
Considering the number of 'extras' included in the oem pcm code, it is tough not to prefer the oem item. With the hundreds (maybe thousands) of man hours put into the design (complexity and thoroughness) of the oem pcm, it becomes a very formidable (nearly impossible) task for aftermarket to compete, what with the budget oem sets aside, for their pcm development.
Although, if the vehicle is to be driven zero miles on the street, the playing field becomes more favorable for the aftermarket.
Highlander
09-29-2004, 05:42 AM
after checking that 2barfile that floated around (just cal changes to use the 2bar) i was thinking, why not lower the injector constant to 1/2 and scale VE for those running speed density???? So VE can actually go higher than 100%?
