3rd gen Z28 for sale real nice
i will email pics at request.
56000 Miles ·8 - Cyl.
·2 doors·5 speed (world class)
·Used·Clear title
·Black Exterior - Gray - Dark Interior
Options
·Air conditioning·Power Locks·Cassette
·Power Windows
1986 Chevrolet Camaro Z-28 (Chevy Z28) Nice
Vehicle Description
krisjoe@usadatanet.net : The car has really been a
great car for me. I have owned it for 7 years and I sold it once about 3
years ago for a week, and then got it back because I missed it. I only put
a few hundred miles on it last year, I have just purchased a new home and
it is time to buy a "family car" I currently keep it under blankets in the
garage, and the car has never seen rain! The car was professionally
converted from a auto to a high performance world class 5 speed. I have
replaced every sensor in the car, I mean every one, i replaced all the
relays, not because they where bad just because I wanted the car to be
perfect. The car has no rust, new tires, brakes front and rear, new brakes
lines braided,everything is new - all of the bushings in the front and
rear, the suspension has been redone - I have done it all. The car is done
for performance and done correctly. In addition, it also rides great. I
have put a new headliner in and also installed the upper console with the
flash light, 145 speedo, iroc grill with iroc fog lights, The paint was
done by a custom hot rod shop, it was striped to bare metal, the door jambs
where done, the trunk was done, and some of the engine bay.The motor has
less than a 1,000 miles on it, the tranny has 10,000 miles on it and the
rear has less than 30,000 miles on it. MODIFICATIONS: GM 350, Jet perf
Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake,
Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super
Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class
t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction
clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers,
Earls braided brake lines, Polygrapite bushings all the way around, poly
tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod,
Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut
tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon
metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor
oil, GM synthetic rear end oil, K&N air filter, Grant steering wheel, 1,200
watt system, Jet Black Paint, (new)91 Z28 rims, (new)92 wing, Tinted windows.
P.S I have A lot of stock parts for this car.
__________________
86Z28,Gm 350,Jet fan 180 switch,Jet perf chip,Q-jet, ,Edelbrock performer intake,Edelbrock headers & cat-back,MSD 6AL,Taylor spiro-pro wires,World class t-5,Hurst short throw shifter,Aluminum driveshaft,BW posi disc rear 3.45's & a posi,PBR calipers and 12 inch rear disc,Crossed drilled front rotors,Earls' braided brake lines, Carbon metallic pads (front),VGX pads(rear),SSM subframe connectors,Edelbrock strut tower brace,GM wonderbar,KYB struts & shock,Jamex lowering springs,Polygrapite bushings all the way around,poly trans mount & torque arm mount,Hotchkis LCA's & panhard rod,Rancho limiter strapes,Jet black,tinted windows, 92 z wing,New 92 z28 16 inch rims,Dual snorkel aircleaner,K&N,1,200 watt system. All fluids are syntheic (mobil 1&Gm)
·Used·Clear title
Options
·Power Windows
Vehicle Description
__________________
Re: 3rd gen Z28 for sale real nice
Sounds like a beautiful machine. I'd be willing to bet that its out of my price range, but could you send pics and a price to T1Orion@yahoo.com ?
Thanks!
Thanks!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jul 4, 2005 05:00 PM
JasonD
Jul 15, 2002 02:17 PM
