Help Please!
josh_95z28
09-05-2004, 09:17 PM
ok, i did the shift skip eliminator mod from http://www.bfranker.badz28.com/96SS/skipshift.htm
then i flushed out the recovery tank and hose that goes from the radiator to the recovery tank
this required me to remove the battery, after i finished all this i reconnected the battery, and then the lights started flashing like the alarm just came on, but the horn was disconnected so it didn't work... i tried to start the car but it wont even make a noise when i do
i think the alarm locked me out, and now i cant start the car, so how would i remove the alarm?
i just got this car 2 weeks ago and i know nothing about what alarms on it, and i dont have anything to turn it off
and whenever i drive the car the orange "SECURITY" lights on
thanks for any help or info anyone can give me
josh_95z28
09-06-2004, 10:13 PM
someone help me, or atleast give me an idea of what i should do to get help
Need4Camaro
09-06-2004, 11:55 PM
You said the "Security" light is on while you drive it? But you said you couldn't even start it up... How can you drive it if you can't start it? :confused:
Well all I know is they keyless entry system and perhaps the alarm are under the passenger side of the console. You might have to have it reset by a dealership.
Best luck to ya...
josh_95z28
09-07-2004, 12:17 AM
before i disconnected the battery, everything worked and the security light was on, but after i disconnected the alarm comes on and wont let me start it
Z28SORR
09-08-2004, 02:23 PM
Did you try locking then unlocking the drivers door with the key? This used to reset the alarms.
