can someone take a look at my FASTfile?
Old Sep 4, 2004 | 03:28 PM
Gearhead6s's Avatar
car is constatly fouling plugs and devloping misses. i have a turbo tech kit on a stock LT1 with ARP head studs and felp-pro gaskets, 75# holley injectors other than that the motor is stock. the racegate has a 5-7# spring it it and i spike above 10psi. i can drive around for about a week on a set of plugs before it seems to develop a miss and the motor shakes, new plugs and the problem goes away for a while. i have the most trouble on decel. when i lift off under boost the A/F drops into the low 9:1s and the car will blow black smoke, but under load its decent. seems to lack a lot of power. if you could take a look at my file i would be very greatful. just PM me of post your email and i can send it to you.
Old Sep 7, 2004 | 12:11 PM
Lethal Injectio's Avatar
Re: can someone take a look at my FASTfile?
Sent me a .GCT file and I will look at it. If you have a log file that would be nice. rtrussell@knology.net
If you will post a little about your tune for reference if you do not have a log.
I assume you run 11.5 A/F target. Do you have WB 02? In the areas on your ve table where you decelerate are the A/F ratios targets in the 13-14 area or not.
I was up there all weekend to watch the game... I could have help you tune!
