Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
How many runs? M7?
Old Sep 29, 2002 | 05:51 PM
Rodrigues's Avatar
How many runs? M7?
How many runs do you think somone will be able to get in the m7 event?
Old Sep 29, 2002 | 06:06 PM
Grover's Avatar
If you don't waste much time between runs you could easily get 20-25 runs in.
Old Sep 29, 2002 | 06:07 PM
Timberwolf's Avatar
during T&T you should be able to get a dozen runs, or at least we have in the past. Depends on attendance and if you "hot lap" it.
Old Sep 30, 2002 | 04:06 PM
AL SS590 M6's Avatar
Moderator
Heck at M4 or M5 Dave D. did almost 50 passes
How many do you want to make?
Old Sep 30, 2002 | 09:05 PM
2001-WS6's Avatar
If you and your car aren't tired at the end of the day... then you just weren't trying hard enough.
Jason puts on a good show for the M events and you'll be hard pressed to find a better racing day value for what you can do and what you get to watch head down a very good track.
Rick
Old Sep 30, 2002 | 09:45 PM
PhantomTA's Avatar
Moderator
actually it was M3 AL,
M3
57 passes
M4
Frezza's Z28 and i made 0
M5
TA made 9 and ripped the tq arm off the tranny
M6
GS, and i made 6
M3 was the first year i owned my car, i made more passes in my TA then most make their entire life
I have it written down in a notbook somewhere, but its in the hundreds of hundreds (close to 400) I made over 100 passes at St. Thomas alone that year.. not including Ubly Milan or Stanton!
To offset that the next year(99) i made over 200
(00) 15
(01) 3 and 6 in the GS
(02) 0 so far
weird huh?
Old Oct 1, 2002 | 05:07 AM
Moderator
M3
57 passes
Well I knew that it was one of the Ms.
If I remember correctly you even had to go and get more gas
I've got 330 passes on the 'bird in the last 3 years and we're not done with this year yet.
Old Oct 1, 2002 | 09:41 AM
cASe SenSiTive's Avatar
Exposed Member
I think I made like 7 or 8 T&T passes, and then however many it took to go through the semis in brackets.
I wasn't really running a lot though. You should be able to make about as many passes as you want.
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
