Truck/towing question -- cant get reciever out
OneSickSix
09-01-2004, 12:35 PM
So the Sonoma I just bought -- the previous owner had the reciever in it for a loooonnnggg time it looks like. I got the pin out with a hammer (it was rusted in there) and I've been trying to get the reciever out but the f'n thing is like welded in there it feels like. The rust is SOOOO bad I cant get it to move. I'm sure I'm not the only one who has dealt with this before. Does anyone have any suggestions for me? I'm going to go outside and try using my impact driver to try and get the thing out. I've been soaking it with rust-a-way stuff and no luck yet. Someone suggested I tie the reciever to a tree and drive straight away slooowwwlllyyy... :o
IROC5.7TPI
09-01-2004, 12:52 PM
Tie a rope to a tree and yank it out ;)
s_willis
09-01-2004, 12:59 PM
Can you get at it from the back? I had to hammer one out from the back one time.
OneSickSix
09-01-2004, 01:12 PM
I wish. Its solid on the back. I was out there for about 45 minutes using my impact gun and not a damn thing changed... Im really considering the tie-it-to-a-tree idea -- haha.
jp2002ls1
09-01-2004, 02:23 PM
Soak it with WD40, then use a jack and jack the rear of the truck up by the receiver hitch a few times to help loosen it up, then put a ball on it and wack at the ball with a sledge hammer and the receiver hitch should come out. I've run into this problem several times, the tree idea works but is sometimes dangerous so be careful.
OneSickSix
09-01-2004, 04:52 PM
Tried it - not working :-\
Dave89IROC
09-01-2004, 06:22 PM
heat itw/ torch and yank w/ tree
IrocSS85
09-01-2004, 08:47 PM
do that AND whack it with a BFH. the vibration from the beating will help dislodge the rust while the heat will help the hitch expand releasing its grip, and the tree applying pressure to pull it out. just make sure your vehicle has room to jump forward, and dont stand behind the receiver as when it comes free, it may fly out and hit you back. good luck
chris
ws6transam
09-01-2004, 11:16 PM
I'd heated one out before, where one of us sat with a oxy-acetylene torch that got the hitch hot all over, then the other guy slammed on the ball with the sledge. We beat it out over the course of little 1/32 inch whacks but it eventually wiggled out. After that we sand blasted the inside of the receiver and painted with barbecue black paint.
Unfortunately the beating destroyed my nice lead hammer :(
limige
09-02-2004, 07:40 PM
i'd use chain not rope to a large tree, apply pressure and tap with a hammer.
are you SURE it's not welded? just be sure, lol.
JoeliusZ28
09-02-2004, 08:08 PM
tie to a tree... and get it on video incase something interesting happens :p
Dave89IROC
09-02-2004, 08:48 PM
I think I'd like to see the tree fall over
would suck if the whole hitch ripped of the truck
OneSickSix
09-02-2004, 09:32 PM
With my luck, the chain would snap and come thru my rear window :\
JoeliusZ28
09-03-2004, 12:02 AM
exactly why i said to have a video camera on hand ;) :p
might wanna wear a helmet :eek:
OneSickSix
09-03-2004, 01:17 AM
Theres a shop I was at today with my brothers 99 S10 getting some front end work done on -- good guys, Okemos Auto... They help me out quite a bit ever since my dad sold their owner a truck ;) He said he could torch it out of there for me, clean it all up, grease it up, rust proof it, and make it useable again. I might take him up on that offer!
Alpine455
09-03-2004, 06:54 AM
Well, I had to do that on my truck. I first used a tow strap tied to a utility pole....the strap broke, and so will your rope.
I thin moved to a chain and wrapped it around a very large cement and steel reinforced pole. Soaked it with wd40 and did a little 1 foot, on the gas yanking. Did that for about 30 minutes. Then started doing that with someone using a hammer. Eventually it came out. I think your best bet is a chain, a large hammer and when its wrapped around the pole, sit in it with your foor on the gas at like 2000 rpm roughyl so it has a bit of pressure pulling on it.
