How do I wire a N2O cut-off switch on my clutch?
What I want to do is turn the solenoids off when I push in my clutch. How do I wire a N2O cut-off switch on my clutch? I've heard of someone using the same switch that the cruise control uses. When the clutch is engaged it turns off the cruise. Anyone done this? Usually when I race I shift by keeping it full throttle and barely tapping the clutch and hitting the next gear. I know that the full throttle switch would shut it off if I lifted on every shift but I don't want to do that. Please help.
Re: How do I wire a N2O cut-off switch on my clutch?
hehe I was thinking about this last night, and that is the same solution I came up with.
jsut a WOT switch, to be engaged only when the clutch is "let out"
stockssn2o
May 25, 2015 08:54 AM
Jul 4, 2005 05:00 PM
