Which size rear end?
Old Aug 28, 2004 | 08:22 PM
95Bluestreak's Avatar
Im lookin at buying a rear end that can handle atleast 450hp from the engine. And later I might put afr heads and a supercharger with alot of boost. Right now the choices are a Moser 12 bolt, Strange 12 Bolt or a Currie 9 inch. The cheapest of the three would be the Strange which comes with my choice of gear. 33 spine axles SS posi and a TA girdle. Next would come the Moser 12 bolt with the same options. And finally the Currie 9 inch with 35 spine axles. All of them come with the posi, my choice of gears. Can the Currie 9 inch accomodate stock camaro rear disc brakes off of a 95 z28? Obviously the Currie is stronger, but how much can a 12 bolt hold? Money is not really a problem, i'd rather spend alot now than double later. For my combonation which would make at most 900hp. Will the 12 bolt hold it for an extended amount of time?
Old Aug 28, 2004 | 09:23 PM
n2ceptor's Avatar
Re: Which size rear end?
I have seen a few threads in the Drivetrain Section..... Might try searching there..
Old Aug 28, 2004 | 09:32 PM
RedHottG2's Avatar
Drivetrain section ?? you actually look in that forum for questions and answers to topics like this ? WHY
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
