How to remove clutch line
Old Aug 28, 2004 | 03:51 AM
Jerm982's Avatar
I've got a hole in the hydraulic line that goes from the master cylender to the slave cylender. Is there any special trick to removing the line? It doesn't seem like it wants to un-screw.
Old Aug 28, 2004 | 11:27 AM
Jerm982's Avatar
Re: How to remove clutch line
TTT I already tried searching and found nothing. Nobody knows how to do this?
Old Aug 28, 2004 | 05:38 PM
JohnD's Avatar
It is held in place with a roll pin. Use a drift punch or appropriate size nail ground off flat to make a cylinder and drive it out of one side or the other. Then it just comes apart. I've done it. It's easy.
Old Aug 28, 2004 | 09:03 PM
dreamer1q's Avatar
That is a sealed unit from the factory, it comes pre bled. I went thru 3 of them trying to rebleed on without destroying it. The above post is correct, but you will get air in the lines, and I guarantee you will have problems. I finally broke down and just paid the 112.00 for the new one and put it one. If you get lucky enough for it to work, please let me know. But I always had the problem of losing pedal pressure after a few days.
Old Aug 29, 2004 | 06:38 AM
JohnD's Avatar
I took mine off in order to flush out the fluid like I do with all hydraulics every 2 years. When I put it back on I used the factory bleed procedure (pump slave rod up and down while holding rod straight down) and had no problems. I'v seen a number of posts on this over the years, I'm surprised you had so much trouble.
BigWil
Mar 29, 2015 12:24 PM
HectorM52
Jan 30, 2015 11:08 PM
Jazsun
Dec 29, 2014 12:14 PM
