IDOXLR8
08-25-2004, 07:40 AM
Ok first of all I want to state I have decided to part the car out only if the engine sells first. Here is the breakdown and please do not try and low-ball me because the prices below are set.
93 Camaro - Rolling Chassis - Currently the body has approximately 75K miles on it. The car has been hit from behind (fixed) and also the front bumper has been replaced. The mouth of the bumper has been cut to allow airflow to the intercooler (not included).
- Moser 9 inch - powdercoated black - Aluminum center section with Detroit Locker (3.50 gear). Also has a back brace welded on. (less than 500 miles on the rearend)
- RK Sport Ajustable Shocks
- Powerslot rotors and performance friction pads
-Spohn Sway Bar
-Spohn Panhard Bar
-Spohn adjustable LCA's
I am asking $3500 for the above. I will not part out the above package so please do not ask.
- Engine Package includes:
Engine has approximately (1500 miles on it)
383 stroker (9.5:1 compression)
Cola Crank
Oliver I-beam Rods
JE -31cc piston
4-bolt mains
CC224/236 cam on a 113ls
CNC LT1 ported heads (heads were decked to get desired compression)
93 intake manifold
Cloyes Double Roller Chain
Hardened pushrods
1.6 Crane Gold roller rockers
This motor was designed for a supercharger
I am asking $4500.00 . Nothing will be parted out so please do not ask
-Arizona Speed & Marine TB ($250.00) - designed for a 93 Camaro
-Spohn Torque Arm - $300.00
-Spohn Heavy Duty Driveshaft - $225.00
-Transmission and Blower kit are currently sold but if something changes I will let you know.
-Bogart Bolted RT Wheels - $1400.00. This will include Morroso tires in the front and MT 28x10.5x15 ET Drags in the rear. The setup has 2 passes on it. Also it is important to note that the front tires have been burnt a little after locking the brakes up at the track. Fits both LT1 and LS1 cars.
- Neil Chance Convertor - Brand New - designed for a TH400 - 4300 stall. This is a welded convertor - $900.00
- FAST System with Fasttrackperformance piggyback harness - $1300.00
- 83 lb fuel injectors - $400.00
- LTCC box will include LS1 coil packs, precut sparkplug wires and modified stock valve covers - $600.00
- Hooker Long tubes and y-pipe are currently sold but if something changes I will let you know.
- ATR Catback exhaust - $325.00
- Autometer Boost and Fuel Pressure Gage - $150.00
- Autometer Tach w/ Shift light - $100.00
- Be Cool Radiator and Spal Fan - $350.00
- CSI Electric waterpump with stock waterpump housing - $120.00
***non of the parts include shipping charges*********
If anyone has any questions please feel free to pm or email me. Thanks
-Spohn Sway Bar
-Spohn Panhard Bar
Cola Crank
Oliver I-beam Rods
JE -31cc piston
4-bolt mains
93 intake manifold
Hardened pushrods
