T56 conversion
Old Aug 23, 2004 | 01:24 AM
Sneakin Deacon's Avatar
T56 conversion
i am doing a T56 conversion on my 93...well, i cant find any damn documentation on anyone doing a 93, just 94-97(which ive been using)...but more specifically the electrical. ive got a 5 wire connecter that went on the 700r4 for the vss gear, but the pigtails i bought for the t56, not one has 5 wires.. if anyone has any experience doing a 93, i would greatly appreciate talkin with ya through pms or whatnot.
Old Aug 27, 2004 | 12:33 AM
Re: T56 conversion
anyone?
Old Sep 20, 2004 | 07:56 PM
ZPaul2Fresh8's Avatar
Question Re: T56 conversion
Have you found the answer to this one yet? I'm doing a t56 conversion on my 93 and was wondering about the 5 wire connector. I assume it will just hang there. I don't think it's for the VSS, the rear connector with 2 wires is for the VSS, or so I assume.
I need to find out how to hook up the Reverse Lockout... in the tutorial it says to tap into a certain wire into the PCM, but that is on 94-97s, 93 PCMs are different.
Anything on this? Thanks
Old Sep 20, 2004 | 08:36 PM
My93Z's Avatar
Re: T56 conversion
I just finished my t56 conversion a few weeks ago, with help from my buddy of mine. I didn't use the 5 wire connector. I just tucked those wires up out of the way. You are right about the VSS connector. I didn't worry about the reverse lock out connector. I hope this helps ya if you have anymore questions let me know.
Old Sep 21, 2004 | 09:12 AM
Re: T56 conversion
yep, the 5 wire connector just got zip tied outta the way..the reverse lockout i didnt bother with...i can mustle through it, it only takes about 60lbs...not enough to throw it in on a race situation, but enough for me to put it in to go in reverse. and i did figure out the VSS thing...it was that connector you referred to...and holy jesus my car is just so much more fun...i really can feel SOTP power because ever since i had my blower on, it roasted auto's and they just slipped and slipped...its fun breakin them loose in 3rd
Old Sep 23, 2004 | 07:22 AM
Darrells93TA's Avatar
Re: T56 conversion
im thinking about doing the same thing with my 93. went to the track last night with a bigger shot, went 11.1 @ 123, 7.2 @ 99. my 1/8th mile mph was 3mph higher than last time i ran and i gained nothing at the end in the 1/4. so my 4L60 is slippin like a ****. i have 3.42s and at the end of the 1/4 i was at 6600rpm's it is slipping so bad.
Old Sep 23, 2004 | 01:52 PM
Re: T56 conversion
for a track oriented car, id stick with the auto...maybe look into a TH350/400 setup?
Old Sep 24, 2004 | 05:45 AM
Re: T56 conversion
Hey, did yous 93 guys ever have a problem with the VSS on your T56 trannies? The reason I ask is because I got mine from a 95Z and the VSS is a little different than my 93. So my speedometer is always pegged.
Any info on this would be GREATLY appreciated!
Old Sep 25, 2004 | 08:16 AM
Re: T56 conversion
yes, i thought it was odd aswell, but the 700r4 in the 93's dont send the same pulse signal as the 94-97 4l60e's...a t56 swap into a 94-97 would show 17/40 of your actual speed.
easiest thing to do if your relatively stock is get a mail order tune that is programmed with the 6spd bin file...biggest problem i had regarding that is a little 40 mile drive equated to about 1200 odometer miles so my car depreciated slightly but was fine once i burned the new chip in
Bxlt1
Sep 29, 2015 03:18 PM
Henson071
Sep 18, 2015 04:01 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
tdigger9899
Sep 7, 2015 10:56 AM
