lt1 parts for sale
lt1 parts for sale
these parts are cluttering up my garage, take them off my hands, all prices are neg. make offers
1. LT1 dual coil valve springs and retainers, all i know is they have 10,000 miles on them, and they were NOT suffient for my xe230/236 cam, should be good for a hotcam, mabye a cc305. $50
2. Stock LT1 aluminum heads off my 95z, have 136,000 on them, ran great before motor spun a rod bearing, will need rebuilding, but good cores, intake valves may also still be good. $150
3. Stock LT1 "pink" powdered rods and pistons, 136,000 on them, rods will probably need resizing due to the spun bearing---make offers
4. Spec stage II clutch disc for an lt1, this is the disc only, has less than 2,000 miles on it. $75
5. Local guys only (atlanta area), WILL NOT SHIP 2 bolt main lt1 block, arp main studs and head studs already installed, bored .030 with 10k on the block, block is ready to go, cam bearings installed, i only ditched it when i found a 4 bolt. $100
6. Stock vented optispark with new cap and rotor (2k on cap and rotor, 136,000 on opti), worked fine, i replaced it with a dynaspark trying to figure out my ignition problem, the dynaspark didnt help which means the original opti was good. Complete with vacume harness. $75
Re: lt1 parts for sale
Whats the story on the heads? I'm looking for some decent cores to have ported. You lost me with "intake valves might be OK". Did a piston touch the head when you spun the bearing?
Do you take paypal?
Do you take paypal?
my box doesnt show full...huh, ohh well...i was just saying intake valves might be good if someone is doing a valve job...normally exhaust valves are the ones that get burnt up and have to be replaced, but they are perfect cores, and ide prefer a money order,
crzhrs, you can call me today after 2:30 at home, 770 998 8600
00WS6mike
Sep 13, 2002 10:37 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
