JamesNobles
08-22-2004, 10:41 AM
Ok guys...I need to know the size or part number for the LT1 T56 bellhousing bolts and studs...I need the ones that bolt the tranny to the bellhousing and the ones that go from the bellhousing to the block....
Please someone help...I need these bolts to complete my T56 conversion!!
PLEASE HELP!!
James
red96taA4
08-22-2004, 07:45 PM
did you try shoebox? (http://www.shbox.com)
Lyle A
08-22-2004, 08:00 PM
Flywheel housing to Engine (6) 22649722
Trans to housing (4) 14056613
Pin, Trans locator (2) 12338075
Stud, Clutch actuator (1) 10150004
Verify these are correct with the dealer before ordering.
JamesNobles
08-23-2004, 09:39 AM
Thanks ALOT MAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I will verify those numbers!! Again.....THanks!!
james
shoebox
08-27-2004, 05:44 PM
I think you were on the 5 speed page when you looked those up. :o
flywheel housing to engine bolt = 10198997
trans to flywheel housing=not listed
Lyle A
08-28-2004, 10:55 AM
oops! That's why I say to double check before ordering. To err is human.
