how to test compression - LS1
teke184
08-21-2004, 03:37 PM
having a misfire problem following each 4k rpm or higher run...
have already checked plugs, wires, coils, injectors, flushed oil and added fuel cleaner.
thinnking it is a weak valve spring or bad lifter....
hoping a compression check will show something.
how do i check it? pull the fuel pump fuse and just crank the engine with the plug out?
or is there another way?
10 seconds
08-22-2004, 02:16 PM
:D Don't know, but make sure your car will not start during cranking and be sure you block the throddle wide open during the test so the car get's air. :D
teke184
08-30-2004, 08:04 PM
what if i disconnect the coil pack connectors? this way none of the cylinders get spark.
somebody has to have tested compression on an LS1 in here!!
shoebox
08-30-2004, 10:29 PM
This (http://shbox.com/1/4th_gen_tech2.html#compression_test) was written for the LT1, but should still work for you. Maybe a minor change or two.
teke184
08-31-2004, 07:13 AM
i should have known you had a writeup on it :thumb:
said it once and i'll say it again....shoebox you are "the man"
