$hawn
08-21-2004, 11:33 AM
Went to start my car and the security light was on, so I waited the 3 mins. or so, the light went out started it up. I checked the resistor on the key and it was 1463, then I checked the resistance on the connector with the key in the on position and it was anywhere from 1463-65 kinda changed every once in awhile. So where does this lead me to next? Thanks
n2ceptor
08-21-2004, 01:50 PM
nowhere, mine did the same thing acouple of times... Computer just didnt read the key right... It happens sometimes because parts are wearing out...
tanmanski
08-21-2004, 09:07 PM
yes, dirty key or lock cylinder contacts are a possible culprit, or...it could lead you to believe the wires from the ignition switch/lock assy contacts (that "read" the key's resistor pellet) are about to break...which is what happened to me. The wires work harden/fatigue after a coupla bazillion turns of the lock cylinder & the wire strands start to break until there's only 1 strand left, which can raise resiatnce enough to trigger the light intermittantly. Once the last strand breaks however...game over. Since you've already done the research, get some resistors & wiring ready to jump the connector at the base of the steering column so you're not stranded when that last strand of wire breaks.
I'm told this is a very common occurence on our cars at around 100 -120k. Mine gave out at 110k. Judging by the number of posts about this topic, I'd say it's going to happen to virtually everyone sooner or later.
good luck
