ram air camaro
08-20-2004, 04:51 PM
who out there are running that cam on a full bolt on LT-1, what times are you running ??
boltons like
1.6 rr
long tube headers
high stall,etc
boltons like
1.6 rr
long tube headers
high stall,etc
xe comp cams 230/236 at 112 lsa on LT-1 stock headsram air camaro 08-20-2004, 04:51 PM who out there are running that cam on a full bolt on LT-1, what times are you running ?? boltons like 1.6 rr long tube headers high stall,etc teke184 08-20-2004, 10:44 PM that's ALOT of cam for stock LT1 castings... i would think it wouldn't be worth it.... ws6transam 08-25-2004, 10:48 PM who out there are running that cam on a full bolt on LT-1, what times are you running ?? boltons like 1.6 rr long tube headers high stall,etc I've got that very same cam in my Minirammed 385 stroker engine, though it's not yet finished. I got the cam from a nearly identical engine, and with a Accel DFI computer, 3200 RPM vigilante, 30 lb. injectors, ported AFR 195's, 3.42 gearing, and a 3500 lb race weight third-gen Trans Am, was supposedly doing high 11's at 119 mph in the Chicago area back in the fall of 1999. HTH, --Dan ram air camaro 08-26-2004, 12:52 PM i also got that cam in my z28 but i wanted to see what times people are running? thanks on the reply's though importeater 08-26-2004, 03:15 PM Im thinking about running that cam aswell with stock heads so Im interested too. onthemat 09-07-2004, 02:56 PM I'm interested in this also. ram air camaro 09-07-2004, 03:48 PM i could tell you guy's by friday night when i try my 94 z28 a-4 w/ the 230/236 cam. unvc92camarors 09-07-2004, 06:13 PM i could tell you guy's by friday night when i try my 94 z28 a-4 w/ the 230/236 cam. be sure to let us know this looks to be the cam i will be going with unless i eventually save up for a custom cam fitted to p/p stock heads ram air camaro 09-11-2004, 04:41 AM bad new's stupid car :mad: , hesitated on the 1-2 shift and wouldn't shift the 2-3 i just kept missing it started at 5800 rpm and stayed there for a wile and jumped to about 6100k and i had to let go of the gas because i't felt like it was going to blow up or something. :( :( here's it 60' 1.968 330 5.809 1/8 8.939 mph 79.24 1000 11.729 1/4 14.344 mph 83.93 :mad: i might want to add the my engine got on fire two days ago for about 10 second's or so not big i also sprayed it with water all over the engine so i think my opti is crapped out,i only burned some vaccum hoses wich i already replaced. sorry guys i dissapointed yall the car felt real strong early that week but not on thurs,friday. unvc92camarors 09-11-2004, 11:12 AM bad new's stupid car :mad: , hesitated on the 1-2 shift and wouldn't shift the 2-3 i just kept missing it started at 5800 rpm and stayed there for a wile and jumped to about 6100k and i had to let go of the gas because i't felt like it was going to blow up or something. :( :( here's it 60' 1.968 330 5.809 1/8 8.939 mph 79.24 1000 11.729 1/4 14.344 mph 83.93 :mad: i might want to add the my engine got on fire two days ago for about 10 second's or so not big i also sprayed it with water all over the engine so i think my opti is crapped out,i only burned some vaccum hoses wich i already replaced. sorry guys i dissapointed yall the car felt real strong early that week but not on thurs,friday. man, that sucks dude:( get that worked out and hopefully you can report back to us with some better results:) Loading 09-11-2004, 02:18 PM That seems like a really low 1/4 for such a low MPH, is that because you couldn't get the 1-2 shift or what? LT1Squirrel 09-12-2004, 12:20 PM That seems like a really low 1/4 for such a low MPH, is that because you couldn't get the 1-2 shift or what? he let off ram air camaro 09-12-2004, 04:35 PM yeah i let off at about the 1/8 mile where it hesitated and all you can see is another camaro pass me up at the end really fast like he had nitrous :p , that camaro ran a 13.9 and i was up ahead pretty good. hey guy's try to help me on this one i'm tryin to look for the cause of the hessatation http://web.camaross.com/forums/showthread.php?p=2472075#post2472075 atljar 09-15-2004, 01:36 AM My buddy ran stock heads, most bolt ons, 3k stall, 373s with 230.236 on 110lsa. Car went 12.19 :) Heres a video of us running each other. I spun really bad. http://www.s89572780.onlinehome.us/CarVideo/Dj12.3vsJared12.4.WMV Here is his 12.19 run http://www.s89572780.onlinehome.us/CarVideo/Dj12.19.WMV importeater 09-15-2004, 08:21 AM wow and on a 110lsa!! how high is he reving that thing? Seems like he's just asking for a spun bearing. atljar 09-15-2004, 12:10 PM Honestly i dont know where his shift points are set. On a dynojet the car made 33X through the 4l60e. Think the car weighs about 3500, it does have a few weight reductions (nothing drastic). | ||
