My a4 shifter is F-ed up, PLEASE help...
I don't even know the easiest way to explain this. But basically, when I turn my car off, the tranny is left in reverse because that is the farthest forward I can physically "upshift" the tranny with my shifter. DOes anyone, have any kind of idea what would cause this. We just did a tranny swap about two months ago, and this just started.
I makes me nervous, because when I start the car up it is IN gear and in reverse
Please advise
Please advise
Re: My a4 shifter is F-ed up, PLEASE help...
Get underneath the car, and look at the bracket where the shifter cable meets the tranny and is bolted up. Chances are those 2 bolts are either A) loose, or B) missing
. The same thing happened to my friend's '96 T/A, and this problem was posted awhile back too.
Replace or retighten those two bolts (they share duty as 2 of the tranny pan bolts as well) and your shifter should work fine again
.......otherwise, I'm lost!?
. The same thing happened to my friend's '96 T/A, and this problem was posted awhile back too.Replace or retighten those two bolts (they share duty as 2 of the tranny pan bolts as well) and your shifter should work fine again
........otherwise, I'm lost!?
CARiD
Sep 7, 2015 08:21 AM
