need help FAST please. got Q??`s about the 9 bolt
Old Aug 18, 2004 | 09:58 PM
Chris`s85Z28's Avatar
Question need help FAST please. got Q??`s about the 9 bolt
Ok I found a borg warner 9 bolt for sale for $300 with disc brakes. I know there better then the 10 bolts by alot, do the 9 bolt`s have C clips??? and what gears do they have?? I popped the diff cover and it looks good inside. how do I tell the gears, will the ratio be stamped on the ring gear??? it still has the tags but there so rusted I don`t know if I can read them. are they hard to rebuild?? and how much do you think it would cost to rebuild it. If I get this rear end I plan on putting it behind my 383 with atleast 400hp + I`m going back to look at it again on friday so what ever you can tell me about the 9 bolt would be VERY helpfull. Oh and is the posi rebuildible?. The guy I`m buying it off of has NO CLUE what this rear end is, He thinks it a 10 bolt, but I know it`s a 9 bolt I knew as soon as I saw it. it has the rubber plug in the diff cover and I counted the bolt just to make sure and theres 9 . I`m going to try to get him down to 200-$250 since he said he just wants it gone
Old Aug 18, 2004 | 10:03 PM
Spinner's Avatar
Re: need help FAST please. got Q??`s about the 9 bolt
10 bolt > 9 bolt
Old Aug 18, 2004 | 10:13 PM
OutsiderIROC-Z's Avatar
There should be some numbers stamped on the ring gear. My 9-Bolt I bought for my Firebird had 37/10 stamped on the ring gear for 3.70 gears.
Old Aug 20, 2004 | 01:57 AM
cals400ex's Avatar
my buddies had 3:27's in it if i remember correctly. it was out of an 87 iroc with an L98
Old Aug 20, 2004 | 08:17 AM
87DJP2001's Avatar
The most common BW 9-bolt ratios are 2:77, 3:27 & 3:45 for TPI cars. The best year for a 9-bolty would be 1989 for the PBR brakes. The ratio will be stamped on the ring gear. Most of the ratios I mentioned will be limited slip and have 28 spline axle shafts. Other ratios that came on early Carb cars are a whole different matter and could have anyyhing. I would stay away from them. As a point of info, Parts are rare, hard to find and expensive. Check for info on www.thirdgen.org for additional info. I have a 89 BW that I swapped on to my 87 IROC and I am glad I did, it was a good upgrade (the best part was the 11.655 rotors & aluminum calipers with a working parking brake).
Old Aug 20, 2004 | 11:08 AM
slayer6x6's Avatar
I saw 9 bolt ring and pinion gears going for around $300 on ebay
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
ChrisFrez
Jan 11, 2015 03:47 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
