What size is this carb?
Old Sep 27, 2002 | 11:12 PM
yzguy's Avatar
My dad was under the impression it was a 750 or 780 Holley Spread boar (Holley with Q-jet bolt pattern, small primaries, and large secondary). It is a vacuum advance Holley, but I am not sure what size. In an old holly number list I have I found a 0-7005-2 that says it is a 650 CFM, is this correct?
does anyone else have a source to look this up?
BTW on the choke it reads:
LIST-7005-2
2699
Thanks,
Mark
Old Sep 28, 2002 | 05:17 AM
Camaro73's Avatar
To my knowledge, Holley doesn't make a 750 spreadbore, just a squarebore.
650 sounds about right.
Old Sep 28, 2002 | 10:10 AM
Bill B.'s Avatar
carb size
My guess is that if the Holley listing matches it with a 650 cfm, then that is probably what it is. If I remember correctly, Holley did make a spreadbore carb in an 800 or 850 cfm, but I'd still say that this one is likely a 650. You might try and search the web for their website and see if they have any more info.
Hope that helps!
Bill B.
Old Sep 28, 2002 | 11:18 AM
yzguy's Avatar
here is what I found... and it lists it as a 650...
http://www.holley.com/HiOctn/ProdLine/CarbList.pdf
thanks
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
Kawi
Sep 28, 2015 09:01 AM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
