How Much Will Subframe Connecters Improve 1/4 Mile Time?
ZZ17IROC
09-27-2002, 05:49 PM
IF I INSTALL SUBFRAME CONNECTERS AND BMR LOWER CONTROL ARMS W/RELOCATION BRACKETS ON MY CAR HOW MUCH WOULD I KNOCK OFF MY 1/4 MILE TIME? I'M RUNNING 12.54@108 RIGHT NOW.:D
96z
09-27-2002, 10:11 PM
Depends, whats your best 60'?
TedH
09-28-2002, 09:48 AM
Depends. Lots of variables. Bear in mind you will be adding weight.
Guido67SS
09-28-2002, 12:18 PM
You should think more along the lines of, "If I put frame connectors on my car I won't have to worry about twisting the car."
Good Luck
kevkop94TA
09-28-2002, 01:57 PM
The only thing about installing SFC's is that it might actually hurt traction a little. It allows for less chassis flex, which actually can increase spin. However the LCA's and relocation brackets will more than make up for it. :D
GREGG 97Z
10-01-2002, 02:33 PM
My thoughts exactly. I added SFC's a few months ago, I certainly wasn't expecting them to decrese my times. I would just like to be able to keep closing my doors normally :D
T/A lt1
10-02-2002, 09:32 AM
Yeah your not going to see much difference et wise but t-tops will keep lining up. :D
357 RS
10-03-2002, 03:48 PM
I just got some weld in SFC's and I was wondering how to install them. On e is straight and the other is shaped like a J. Which on goes on which side?
