frankromano
08-13-2004, 07:13 AM
i am thinking i need a new clutch. i have an 02 with 27k miles on it. shifts fine (never misses or anythign), but i have to push it all the way to the floor to engage.
how would i konw?
can someone also explain to me what a stage 3 and 4 are? i can't find anythign when i did a search and would like a good understanding. is that the only thing i would need to buy-what a bout the flywheel-not sure how that connects to all this. thanks alot. frank
therealmagyver
08-13-2004, 08:14 AM
Your clutch is fine. I think your master or slave cylinder is causing that disengaging issue you are having.
frankromano
08-17-2004, 06:44 AM
hi thanks good to know. anything i need to do?
Camaro00_ss
08-19-2004, 10:22 PM
Master and slave cylinders are all hydraulic, if you have a leak (which would cause your problem) or if either cylinder is faulty, replace the entire assembly, like I did. Get yourself a Mcleod adjustable master cylinder, good investment for higher-horsepower engines, if your'e going that way.
Don't know what specifically your'e asking for about stage II's and III's, but the difference is about horsepower ratings. Each manufacturer has a different rating scheme too. Usually refers to Spec Clutches I-IV tho.
frankromano
08-21-2004, 12:09 PM
yeah, i was just curious what they meant with stage 2 and 3 but you answered it.
i hope the cylender is covered under warranty, something tells me its not!
Camaro00_ss
08-21-2004, 06:36 PM
That depends...Have you removed the master or the slave recently? Can the leak be a result of anything you have done or had done to the car? If not, then yes, it's covered under warranty.
frankromano
08-22-2004, 09:34 AM
nope, i havent done any mods! (airlid)
