Brake job....how hard?
Old Aug 12, 2004 | 03:18 PM
Knowklew's Avatar
Question Brake job....how hard?
well i am going to be doing the front brakes on my car and i wanted to know how hard it is. I have done brakes on other cars before just not this car so i am not familiar with them. Can anyone let me know what tools i will need along with any tips or tricks. I am going to buy new rotors and pads for the front.
Thanks,
Fred
Old Aug 12, 2004 | 03:27 PM
Compstall's Avatar
Re: Brake job....how hard?
If you've done brakes before there is nothing trivial about these. You'll figure it out once you get started. Basic hand tools will get the job done. It's not hard.
Old Aug 12, 2004 | 03:34 PM
Camerone222's Avatar
Agreed with above. All you need really is a rachet and maybe a screwdriver, as long as you have done brakes before you will be fine. It should take a little less than 20 mins all said and done
Cameron
Old Aug 12, 2004 | 06:24 PM
BADAZ28's Avatar
I changed the rotors and pads also, and it took me like 45min. It was the first time I ever changed brakes also. Just basic hand tools are needed.
Old Aug 12, 2004 | 06:40 PM
Slappy3243's Avatar
Just make sure you have a good c-clamp. It comes in handy when doing brakes as you probably already know. I would say I had the easiest time changing F-body brakes then compared to other cars. Just make sure you clean the pistons as best you can with some brake cleaner to avoid squeaks.
Old Aug 12, 2004 | 07:13 PM
Kataklysm's Avatar
You'll need a c-clamp, 3/8ths (pretty sure thats the size) hex key/socket and a screwdriver (to get old pads off easy) Theres 2 bolts holding each caliper on, take them off then pull the caliper off (might need to use a hammer gently.) Recompress the piston with the old pads on there then take old pads off and replace with new. Put calipers back on and pump the brake before you drive unless you want to crash.
Old Aug 12, 2004 | 08:59 PM
CrAkD X 95TA's Avatar
brakes are simple i did my pads and rotors in like half hour and im not even remotely into mechanics.
Old Aug 13, 2004 | 05:56 AM
CHRISCAMARO's Avatar
Wink Re: Brake job....how hard?
i always put on new rotors-they wear out real quick. i had to replace the factory ones at 13k.
easy job (especially if you have an air rachet :-) -good luck
Old Aug 16, 2004 | 04:45 PM
Aeromaks's Avatar
Actually he has an ls1. ls1's dont use hex keys/sockets.
go to installuniversity.com or whatever it is they have a writeup for ls1 brakes. at first I thought they were the same till I had to run to home depot for our 3/8th hex socket. =)
Old Aug 16, 2004 | 07:01 PM
bbbeast's Avatar
Thumbs up Re: Brake job....how hard?
Nice thread and just in time, too...I have rotors and pads on the way for my Z28, also. So, I was kinda curious about some the stuff concern the install process on these. Basicly, all good advise so, it shouldn't be all that bad to perform the front brake/rotor job. Where I can get reid of the warped rotors on the Z.
Thanks,
Don
Old Aug 16, 2004 | 10:47 PM
Knowklew's Avatar
So who knows where to get a good price on pads and rotors? And i might not need rotors but i know i need pads.
Old Aug 16, 2004 | 10:50 PM
Aeromaks's Avatar
For pads i go with Jegs usually, cheapest price on Hawk pads, for rotors, usually go with blank oem's from strauss when they have 20% off which is like every other week. hehe.
Old Aug 16, 2004 | 10:58 PM
ls1_bc's Avatar
Thanks,
Fred
Go here for a step by step
http://www.installuniversity.com/ins...ds_mwarren.htm
Good Luck
Old Aug 16, 2004 | 10:59 PM
MasterEvilAce's Avatar
whaat? i don't think you should be going through rotors that quick
F'n1996Z28SS
Aug 23, 2023 11:19 PM
May 1, 2015 01:14 PM
dluna333
15
Mar 13, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
