dj haf
08-08-2004, 02:54 PM
im putting the hsr on right now, and i wanted to know if anyone had suggestions on where i should set the timing and fuel pressure? i have a 350 bored over .030, comp cams 503 cam with 1.6 rr's, ported l98 heads, around 10:5 to 1 cr, and 24# svo's. with the tpi setup, i had the fp set at 44-45 psi on my tpi setup because it seemed to run pretty good with 45 psi. i heard that the hsr likes a lot of timing and a lot of fp, so i just wanted to find out if anyone had some advice to give me for my application. thanks guys
mrr23
08-08-2004, 05:32 PM
just start at the same point. but just to give you an idea on my 360 i had with the ZZ4 cam and L98 heads, i used 45 psi and timing was 36* by 2500 rpm. now on the 383, i used 55 psi and 36* by 2500 rpm. on both, i had the 24# accel injectors.
aklim
08-08-2004, 11:52 PM
I used stock fuel pressure and 6 deg timing.
dj haf
08-09-2004, 01:14 AM
6* btdc? have you had your car tuned?
aklim
08-09-2004, 01:50 AM
Yes I did. Timing was set at 6 deg and the pressure was about 45-57. It made about 410 HP at the wheels. I don't know what the ECM was supposed to advance it to but that was what I set it at. It was dyno tuned at HiTechMotorsport in Ramsey, MN.
