hilarious track times ('03 Cobra)
Saw some pretty funny times at the track last night. Z06=12.9's numerous GT's=15's saw an '02 SS with exhaust 4.10's and DR's run 13.6's. And the best of all '03 Cobra ran a 15.3!!!! I don't think he ever got into the 13's either. I ran a 13.9 which i dind't think was too bad.
TONY
Oh i've been seeing all of these "altitude corrected" times, this was at 1100ft. would that make any difference?? couldn't be much
TONY
Re: hilarious track times ('03 Cobra)
Yes, altitude makes a difference, but what you REALLY need to know is Density Altitude (DA). What you need for a DA calculation is:
1a) basic elevation and barometric pressure
OR
1b) station pressure
2) air temperature
3) dew point
http://wahiduddin.net/calc/calc_hp_dp.htm
The bottom line is that the most important factor is air temperature, then barometric pressure, then humidity. The reason air temperature is so important is that it's so variable. Some guys race in 50 degree weather at night, others (like me) have to race during the middle of the day in 85 degree weather. As a for instance, using the same altitude, same barometric pressure, dew point 20 degrees less than air temperature and the Density Altitude is:
50 degrees: -610'
80 degrees: +1491'
OR
2) air temperature
3) dew point
50 degrees: -610'
80 degrees: +1491'
TONY
TONY
We have similar mods and run similar times..
F'n1996Z28SS
Aug 23, 2023 11:19 PM
teedoff59
Aug 8, 2002 01:36 AM
