SMOKNZ
09-26-2002, 10:27 PM
I just got a set of corvette fuel rail covers for my 97 Z28. Just wondering what needs to be cut from them, if anything at all, and if anyone has any pics before i start this job. Thanks!
Bill
Bill
Fuel Rail Cover InstallationSMOKNZ 09-26-2002, 10:27 PM I just got a set of corvette fuel rail covers for my 97 Z28. Just wondering what needs to be cut from them, if anything at all, and if anyone has any pics before i start this job. Thanks! Bill luis nunez 09-26-2002, 10:49 PM How much did you paid for them? I want to buy for my Z :cool: 96_LT1 09-26-2002, 11:54 PM you really dont have to cut anything from them......when i did mine i drilled the two holes for the fuel lines instead of cutting.......i cut a half circle on the pass. side cover where the pcv hose goes into the manifold, and i had to trim the section by the map sensor on top of the manifold......you can cut but if you want the "factory look" you can make good use of a dremel and end up with great results. SMOKNZ 09-27-2002, 06:50 AM They were about $22 a peice thru Sam Taylor, a dealership. http://samtaylor.com/html/parts.html You wanna email or call Jason Cromer. I also got some Camaro billet inserts that attach to the covers. I'm just trying to figure out how they attach to the car. Each one has 2 plastic tabs that look like they go into the fuel rail, but is that all that holds them on? Bill badz28white 09-27-2002, 07:16 AM Here is a link to a past post on fuel rail covers. I have a set of these and they are great. Custom made for the Z might want to check it out http://web.camaross.com/forums/showthread.php?s=&threadid=22693&perpage=15&pagenumber=5 akrott1 09-27-2002, 07:45 AM Originally posted by badz28white Here is a link to a past post on fuel rail covers. I have a set of these and they are great. Custom made for the Z might want to check it out http://web.camaross.com/forums/showthread.php?s=&threadid=22693&perpage=15&pagenumber=5 Thanks BadZ28White....Glad you like the covers.... Here is a direct link to pictures of the covers that I have for sale....I made a set for myself and posted some pics....and had alot of interest, so decided to make a bunch of sets for the members of this board, but have only sold about 1/2 of the sets I have made. If you are interested shoot me an email (krotta@tmdinc.com) http://community.webshots.com/photo/45333320/50325501XaCHtd 96 TA 09-27-2002, 08:20 AM I bought a pair of akrott1 fule rail covers and like them very much! Their very durable and you can customize them any way you like. And not cutting is envolved 96_LT1 09-27-2002, 09:03 AM Originally posted by SMOKNZ They were about $22 a peice thru Sam Taylor, a dealership. http://samtaylor.com/html/parts.html You wanna email or call Jason Cromer. I also got some Camaro billet inserts that attach to the covers. I'm just trying to figure out how they attach to the car. Each one has 2 plastic tabs that look like they go into the fuel rail, but is that all that holds them on? Bill you will need to pick up the 4 LT4 intake manifold studs for the covers. they screw into the base of the intake manifold and the covers snap onto those studs and the 2 plastic nubs on each cover sit in the holes on the fuel rails. you might also have to reroute the brake booster line around the driver valve cover for better clearance. | ||
