SSHORTT
08-03-2004, 12:32 AM
will this fit on my stock exhuast system anywhere?
flowtech cutout 3'' slip on "WIll THIS FIT?"SSHORTT 08-03-2004, 12:32 AM will this fit on my stock exhuast system anywhere? jchevy 08-03-2004, 12:45 AM What do you mean by 3" slip on. I know a normal 3" cutout will slip over the stock 2 3/4" 4th gen I-pipe, LT1 cars anyway. Does the slip on mean that is a 3" cutout flared to slip over 3" pipe? SSHORTT 08-03-2004, 01:16 AM What do you mean by 3" slip on. I know a normal 3" cutout will slip over the stock 2 3/4" 4th gen I-pipe, LT1 cars anyway. Does the slip on mean that is a 3" cutout flared to slip over 3" pipe? He had it on here a while back.... http://web.camaross.com/forums/showthread.php?t=288198 will it fit? jchevy 08-03-2004, 01:30 AM That link is to a high flow cat, not a cut-out. If its a cat you are looking for you need to know what size your y-pipe is, my guess would be that an exhaust shop can make it fit with no problems. SSHORTT 08-03-2004, 01:32 AM That link is to a high flow cat, not a cut-out. If its a cat you are looking for you need to know what size your y-pipe is, my guess would be that an exhaust shop can make it fit with no problems. :cool: I meant this one :cool: :rolleyes: SSHORTT 08-03-2004, 01:34 AM http://web.camaross.com/forums/showthread.php?t=286002 jchevy 08-03-2004, 01:36 AM Yup, it will fit in the I-pipe, which is where you want it i assume. Its where 99% of people put them, including me. The other 1% has true duals and runs two of them, one off of each collector. SSHORTT 08-03-2004, 01:50 AM If i get this cutout will i ever need to put in a cat-back exhaust or does this get the same results with the stock pipes. and BTW thanks for all the advice jchevy 08-03-2004, 01:53 AM I dont have a cat-back, just swapped out the muffler for the more agressive sound oun the street. open up the cutout at the track for preformance. If you have cats you will probably be able to run the cut-out open all the time. Its way to loud with no cats and headers, also sounds like crap. SSHORTT 08-03-2004, 01:59 AM how much difference can you feel with it opened up? jchevy 08-03-2004, 02:16 AM It will actually feel like it made it slower, you will lose some low end tq, but will increase peak power. Just do it, if you dont like it, cap it, you are out $35 for the cut-out and $30 for the install. :D | ||
