bunker
08-01-2004, 12:04 AM
I noticed today while dynotunning that my A/F was at 12.0 with -10 in the PE table for PE vs. RPM, well I went to -20 & it made no difference, I then went to -30 & still no difference, acctually it went a bit richer to 11.9 A/F on the wideband & the o2s were reading higher.
Is there a sertain point where the PCM just ignores the PE table numbers past a sertain value? I figured maybe its because the PE vs. TEMP was at 16 so putting anything less then -16 ie. -20 the PCM gets confused? Or is there just a number where the PCM just doesn't listen? I'm wondering maybe I should have altered the PE vs. TEMP portion after I saw it was doing anything, but I altered the MAF table a bit & it went leaner.
So I'm just wondering what if there is one is the cut off point for going leaner in the PE table, ie -10, 15, or what?
Thanx guys.
Matt.
Thanx guys.
Matt.
