02z28camaro
07-29-2004, 08:43 PM
how do you all recommend cleaning under the hood? i have an 02 z28.
how to clean under the hood02z28camaro 07-29-2004, 08:43 PM how do you all recommend cleaning under the hood? i have an 02 z28. gav'spurplez 07-29-2004, 11:15 PM do you have access to an air compressor ?? i used gunk engine brite foam. let it soak for about 10 minutes and hosed it off. i was at work and just used an air gun to blow all of the water off. then, dried what i could with a towel. sprayed on CD-2 engine detailer. http://f2.pg.photos.yahoo.com/ph/gavspurplez@sbcglobal.net/detail?.dir=/66d2&.dnm=6908.jpg lt1aggie 07-30-2004, 10:04 AM bucket of water, spray bottle, and a toothbrush :D Cmr0z28 07-30-2004, 11:41 PM Simple green, 303 Aerospace protectant, some brushes, rags, etc camarochick350 08-08-2004, 06:24 PM I just cleaned mine again this morning. I spray it with some simple green and let it sit for a few minutes, spray that off, (if you got an air conpressor that would help), then spray armor all on it and wipe it off. Works great. :) | ||
