Cruise mode shift points?
sabre81
07-29-2004, 05:28 PM
whats cruise mode? should i edit these values on a gear change?
PoorMan
07-29-2004, 11:40 PM
You must have a newer version of TunerCat then me. I don't have a "cruise" table. Anyway, I am assuming you still have the normal and performance tables?
J
sabre81
07-30-2004, 09:56 AM
yes :) crusei table is right under normal and perf. And i know its used because in datamaster there a logged switch that flips between yellow and green.
PoorMan
07-30-2004, 03:25 PM
huh. I would take a guess and say that the MAP is a function for that table in some way. For example; low MAP=use cruise table or something like that.
sabre81
07-30-2004, 06:57 PM
yeah guys at tunercat said its used in low load conditions. heres a screeshot of the values.
http://home.adelphia.net/~sabre81/stuff/untitled.jpg
looks odd to me why would 3->4 be lower than 2-3
PoorMan
08-10-2004, 09:44 PM
Coming to a stop (0% TPS) and downshifting into 1st at 26 mph you will hit your head on the stearing wheel. :) That table looks strange.
