SBC in a '94
94patriotredZ
07-27-2004, 11:45 PM
I am about done with my car, WE are about done putting a 383 sbc in a 94 Z28. WE have found that the bolt pattern on lt-1 heads is the opposite of standard sbc heads (front and rear patterns are swapped) So, my accessory brackets won't work. I'm told v-6 brackets will work. If anyone has done this, where did you put the AC compressor? Any help would be appreciated.
Brady
07-27-2004, 11:52 PM
In the dumpster, behind the shop ;)
94patriotredZ
07-27-2004, 11:56 PM
Well, I'm going to be driving it daily for about the next 2 years. When i decide to just race it, i'll get rid of the sbc and the AC at the same time for an alloy BBC.
Mindgame
07-28-2004, 01:14 AM
Check with Street & Performance http://www.hotrodlane.cc/
I don't know if the V6 bracket will work but you could easily pick one up at the local wrecking yard. That or at least make a quick test template.
Good luck.
-Mindgame
