Holy crap check out this wideband..
Alvin@pcmforless.com
07-27-2004, 11:30 PM
I just bought one up..
thats $260 including the sensor!
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7913082195&ssPageName=ADME:B:EOAB:US:6
wile2k
07-27-2004, 11:45 PM
It's a bit more but I prefer this one.
http://www.innovatemotorsports.com/lm1.php
If you get in on a group buy it could be had for just over $300. Amazing how inexpensive a decent wideband setup is getting.
Rodrigues
07-28-2004, 12:04 AM
The innovate motorsports output can be modified to work with the accel gen 7 setup too ;)
07-28-2004, 12:09 AM
what are you talking about 0-5v output..
all of them do that.
96TurboTA
07-28-2004, 04:05 PM
The innovate unit uses a readily available wideband sensor. You can find them for less than $50. The unit you just bought uses an L1H1 or L2H2 which cost anywhere from $150 to $300. The L1H1 is on the higher end because it's very hard to get.
camarossguy2
07-28-2004, 09:15 PM
sweet, there in daytona
arnie
07-28-2004, 09:44 PM
WB O2 sensor controllers are not manufactured equal. Some are more accurate (across a full range) than others. Wish you accuracy with yours. However, without checking against a known standard, won't ever know, will you?
07-28-2004, 10:03 PM
What the hell,
I'll do that.. I'm a professional tuner and have 3 other widebands I can check it on.
The controller doesn't determine the accuratcy its the sensor. AND this controller is using the same sensor as my tech edge setup.
arnie
07-28-2004, 10:29 PM
I rest my case. :) If you consider that controller of pro quality accuracy, then consider me wrong.
07-28-2004, 11:07 PM
um, well actually TODAY while tuning a mustang I had my tech edge up one tail pipe and a dyno jet double pump wideband on the other..
Both read so close to each other you couldn't tell them apart.
So rest your case until you got first hand experience
96TurboTA
07-29-2004, 12:16 AM
What the hell,
Actually the controller has just as much to do with the accuracy. You should know this from the info on the techedge site alone.
