BiGGinZ
07-27-2004, 07:53 AM
Would a 1LE Panhard rod be any improvment over the stocker? I know there could be better improvment with other peices but just looking for a little better handling for everday driving, thanks.
1LE Panhard rodBiGGinZ 07-27-2004, 07:53 AM Would a 1LE Panhard rod be any improvment over the stocker? I know there could be better improvment with other peices but just looking for a little better handling for everday driving, thanks. Red96Lt1 07-27-2004, 09:41 AM You will probably see very little difference till you hit the corners hard. LT4Firehawk 07-27-2004, 12:22 PM 1LE panhard rod is just a stock bar with harder bushings. Skip it and go for a double adjustable rod-end panhard bar if you are going to upgrade. This was my choice for a bar (and I had the 1LE unit): http://www.unbalancedengineering.com/Camaro/PHR/ O-taka 07-27-2004, 03:46 PM that's nice i could feel a diff going from the 1LE weak stamped panhard to a BMR double adj, not rod end, just poly. needed if you go to 315s rear teke184 07-28-2004, 12:26 PM for the $90 or so they cost, you may as well just get the BMR poly bushing PHB ... there was even a 15% discount in the group purchase forum that i think is still going on. makes it really worth it | ||
