$hawn
07-26-2004, 07:36 PM
I'm changing my front shocks, and I thought I heared or read somewhere that you need to remember how something lines up or the alignment will be off. I though that the alignment changing was all in the control arms and no alignment will be needed as long as your not changing the springs? Thanks for any input.
Injuneer
07-26-2004, 10:32 PM
You have to mark the spring shock assembly before you take it apart, so the top and bottom mounts align properly to the holes in the shock tower and the lower A-arm when you reassemble them.... its the alignment of the holes that is an issue.... not the steering alignment.
$hawn
07-27-2004, 12:35 AM
Oh, ok I gotcha, I thought I read something about the steering alignment being an issue. Thank you.
Hyperspeed97z28
07-27-2004, 10:44 AM
So one does NOT need an alignment after a shock install ???
