Inside of tail pipes are white??
Old Jul 26, 2004 | 12:07 PM
MetallicTrans96's Avatar
I have just noticed that the inside of my tail pipes are white now after n20 and running race gas in it....do i have anything to worry about???
Old Jul 27, 2004 | 09:34 AM
ford's Avatar
Re: Inside of tail pipes are white??
I wouldnt worry, its usually just when you ran it really lean it melted a bit of the piston skirting which turns white when it burns.
I have no clue, but i thought id scare the hell out of you
Old Jul 27, 2004 | 11:14 AM
donot_4get's Avatar
LMAO
Old Jul 28, 2004 | 12:28 AM
amean94ta's Avatar
some fuels like the rocket brand that i run have a chemical in them that do that. alot of people have tried to tell me i was lean also
Old Jul 28, 2004 | 12:50 AM
OffspringZ28's Avatar
id slap it on a dyno. just to make sure. dont wanna be running lean
Old Aug 3, 2004 | 10:38 AM
NVMYZ28's Avatar
Thats common when running some types of race fuel - its usually not the best for your O2 sensors but it wont necessarily kill them right off the bat either...
Old Aug 3, 2004 | 12:54 PM
formula383's Avatar
It is just the fuel, when I put the 110 fuel in my bike the exhaust tip of it turns completely white as well.
Old Aug 3, 2004 | 01:07 PM
94z'sson's Avatar
dont worry about it unless it keeps happening a lot
Old Aug 7, 2004 | 11:42 PM
pwrhngryj's Avatar
Thumbs up Re: Inside of tail pipes are white??
The white is more than likely the cause of the lead they put in the race gas. the residue plugs cat's and kills O2's so dont use it too much. I would run unleaded race gas if you have either.
Old Aug 9, 2004 | 11:42 AM
NtenseZ28's Avatar
The odds are it's not a lean condition causing it, unless you drive to store and work everyday juicing the snot out of ur car. Most likely a by product of the gasoline you used. I can't say I've ever seen a exhaust turn white from running lean a couple times at the track, not without seeing some parts of ur engine chillin out at the bottom of ur oil pan...
Old Aug 18, 2004 | 09:52 AM
Will84's Avatar
I don't run race gas... but my friends Supra always has white residue on the pipe after making a pass with 110. It's not a lean sign... it's just the gas.
Klypto
Parts Wanted
Apr 22, 2015 07:08 AM
Ringmaster72
Apr 2, 2015 08:32 PM
carl.froehlich
Mar 13, 2015 12:38 AM
CaRParts102
Dec 6, 2014 08:45 AM
Rich_z28
Sep 13, 2002 03:35 PM
