JoshMcMadMac
07-26-2004, 08:28 AM
I tried searching, but could not find any help. I have lowering springs and new shocks for all four corners of a 96 Camaro. I ordered new mounts, and they were shipped in to the store I bought them from yesterday. I had the front shocks/springs pulled out. Come to find out, the mounts were boxed incorrectly, so I got two left-hand side mounts. So, I went back to the store, and they cannot get my parts until tomorrow now. So, I had to put the car back together.
In reassembling the car, I found it quite difficult to get the mounts to go properly into the holes in the fender. Is this typical, or is there a trick I do not know? When removing them, I did the following: I removed the 2 nuts and 2 bolts under the hood for the mount. I jacked the car and removed the wheel. I removed the two lower shock bolts/nuts. I disconnected the sway bar. And then the entire shock assembly came right out. But putting the assembly back in was damn near impossible. Any help?
Also, I went ahead and ordered the new mounts, and sure enough the old nuts are rusted to no end, and will not release the old mount. However, I now realize that I can not get the spring mounts out of the assembly now. Is there a particular name for this part, so I can order new ones? Are they expensive? Or is there a simple way to get these parts out of there that I cannot think of? I really am in no mood to fight with these for hours, just to get a few old parts out that may be cheap to replace. Any and all advice and suggestions are welcome.
