SS Pat
07-24-2004, 06:57 PM
Wanted to know if it is ok to spin the shock's shaft while holding the nut in place with a wrench to tighting it up? Or is it best to hold the shaft in place and spin the nut tight, which is a pain in the neck since there is no space to get a wrench on it and turn?
TA Dreaming
07-24-2004, 07:07 PM
there should be a allen socket on the top of the threads. six mm if im not mistaken. just hold it still while rotating the nut. im not following you too well so sorry if i stated an obvious.
TA Dreaming
07-24-2004, 07:09 PM
just thought about something. if your referring to the rear shocks. youll need someone to hold the shock in place under neath while you turn the nut up top.
SS Pat
07-24-2004, 07:19 PM
I would use an air socket wrench with an allen socket to spin the shaft while holding the nut in place with a open end wrench. Basically I want to know if spinning the shaft will hurt the shock?
SS Pat
07-24-2004, 07:22 PM
Oops! Meant to put this in the suspension forum.
TA Dreaming
07-25-2004, 07:27 PM
no either or, but be forewarned that you will not reach the torque rating with the allen so dont try it
Bilstein specifically says not to spin the shaft because you can damage the shock.
Bud M
08-06-2004, 12:27 AM
SS options:...key fobs
Sorry, that's just funny
SS Pat
08-06-2004, 09:32 AM
Yeah it's funny, but they were really an option.
Well I ended up spinning the shaft, so hopefully they will be ok. Has anyone else done the same with out problems.
