Idle showing very lean on both sides (Need Help)
Old Jul 21, 2004 | 09:02 PM
Black95Form's Avatar
I started up datamaster just to see how things were doing. At idle in closed loop, my long term BLMs were at 158/160. What is going on??? I have a log. Can someone help. I went for a long cruise and logged a bunch. Please help
Old Jul 22, 2004 | 03:59 PM
Re: Idle showing very lean on both sides (Need Help)
Anyone????? Need help badly!!!!
Old Jul 22, 2004 | 04:33 PM
97Z-M6's Avatar
need to know what youve done to the car. like what mods, what size cam. what did you do to the car right before it started this.
these are things that will help help you.
Old Jul 23, 2004 | 04:58 PM
Lloyd Elliot Heads
383 Lt1
224/230 cam 112 lsa 108 icl 608/590 Lift
Hooker Long tubes
4 inch exhaust (recently installed)
I am about to check for any exhaust leaks tommorrow.
Old Jul 24, 2004 | 11:47 AM
I am very confused, I checked the car for exhuast leaks. Cant see any sign of any leaks. What would make the car go so lean on idle. I know prior to putting the 4 inch exhaust on the blms were close to 128/134. Any suggestions. How can I add more fuel in the idle cell. If i do add more fuel for cell 16, do I have to spend time on the dyno for wot tuning?
So many questions, such little time.
Michael
Old Jul 24, 2004 | 12:18 PM
bunker's Avatar
what LSA is that cam on? the overlap will dump extra oxygen through the exhaust causing the sensors to read lean while the engine is prolly way too rich by the time it compensates with LTFT, remember that the fuel thats also thrown out the exhaust isn't picked up by the sensors since they only read oxygen, stock cams don't do this, so you have to work around this, what do you read while driving around? Prolly fine right?
Matt.
Old Jul 24, 2004 | 02:08 PM
112LSA on a 108 ICL.
I can send you a datamaster dump if you can help me. I am at a loss. I am in the middle of doing the mod to my bbk 58 mm throttle body, just to see what that does to the split. Let me know.
Michael
Old Jul 24, 2004 | 05:03 PM
97Z-M6's Avatar
Michael
yes that would be great. send datamaster to vincentbergeron@yahoo.com
Old Jul 24, 2004 | 11:32 PM
Sent you a file that had idle to a cruise around town, then idle again. Let me know what you think.
Michael
Old Jul 25, 2004 | 10:13 PM
Did you get a chance to look at the files I sent you? Let me know.
Michael
edman
Mar 13, 2015 09:39 PM
ChrisFrez
Mar 1, 2015 01:33 PM
ChrisFrez
Feb 22, 2015 08:47 AM
edman
Jan 25, 2015 02:41 PM
