LetMeBurnU
07-19-2004, 10:35 PM
I was looking into the 3.73 pro-street gears by strange and i saw it has 2carrier and a 3carrier. what do they mean by 2 or 3 carrier?
3.73'sLetMeBurnU 07-19-2004, 10:35 PM I was looking into the 3.73 pro-street gears by strange and i saw it has 2carrier and a 3carrier. what do they mean by 2 or 3 carrier? Capn Pete 07-19-2004, 11:38 PM Since you're car is an SS with an A4, I'm 99% sure they came with 3.23 gears, which are on a 3-series carrier (the carrier contains the posi / limited-slip part of the differential, as well as that is where the ring gear bolts to). If you have 2.73 gears, then you've got a 2-series carrier. If you're upgrading to 3.73's, buy them to match the carrier that's currently in your car. slayer6x6 07-19-2004, 11:55 PM The ring gear on a 2 series carrier is a little thicker than a 3 series carrier. LetMeBurnU 07-20-2004, 02:27 AM So a 98-02 z28 a4 is considered as a 3 carrier right? Capn Pete 07-20-2004, 05:53 AM No, not always:no:. The cars using 3-series carriers are 3.23 geared A4's, or 3.42 geared M6's. However, 2.73's are the more common A4 gear, and they are using a 2-series carrier (and they're available through all the years, '93 - '02). | ||
