Mixing Dexcool and Prestone....
Old Jul 19, 2004 | 12:26 PM
Tair's Avatar
What happens when you mix Dexcool and Prestone? DON'T ask me why I brought this up.....
Old Jul 19, 2004 | 12:30 PM
ScrmngChckn95's Avatar
Re: Mixing Dexcool and Prestone....
I assume you're talking about mixing the orange/red antifreeze and the green antifreeze. I've never done it myself, but I've heard on this forum, and at the auto parts store that I work that they form into a gel.
Old Jul 19, 2004 | 04:13 PM
Ryan's LT1's Avatar
It turns into sludge. It's bad.
Old Jul 19, 2004 | 05:33 PM
I have seen the basic statement below stated many times. I have read the same thing said by GM as well.
Mixing a “green” coolant with DEX-COOL reduces the batch’s change interval to 2 years or 30,000 miles, but will otherwise cause no damage to the engine.
Most problems people attribute to Dex-cool are not from mixing with the older coolant.
Old Jul 19, 2004 | 05:56 PM
CrAkD X 95TA's Avatar
I did it by accident cause i was going to switch to dex during a waterpump install since a big mouth friend talked me into it. so i filled the radiator with dex but the block still had green in it I was going to get it flushed as soon as i finished but I ran into other problems and the car sat for awhile. after running for a short period of time when i drained the radiator it was just a lighter orange no sludge.
Old Jul 19, 2004 | 07:31 PM
Tair's Avatar
alright, my brother took the Z out, but I just read in my dad's C5 vette's owner's manual that if you fill up with anything but Dexcool the life is reduced to 2 years/30k miles. It says it in black and white....I guess it's now time for me to go flush the coolant in the Z, lol.
Old Jul 19, 2004 | 08:28 PM
Basically saying that the properties of the coolant revert to those of the green stuff.
Old Jul 20, 2004 | 12:58 AM
Tair's Avatar
awesome, thanks for pointing that out to me shoebox
Old Jul 20, 2004 | 09:20 AM
HBHRacing's Avatar
question.. are you talking about the normal prestone thats green or the red extended life prestone?
Old Jul 20, 2004 | 03:18 PM
Mitch666's Avatar
I just got my coolant and all that stuff replaced. The mechanic told me they had the change the coolant, because someone changed it before and you cant mix or your not suppose to mix coolants. He said if you mix red and green it can turn acidic and eat the system apart.
Sep 17, 2015 11:53 AM
Pwilson59
Sep 3, 2015 08:47 PM
pimpen1024
Aug 19, 2015 08:36 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
warmeck
Mar 1, 2015 08:47 PM
