My little turbo LS1....
Old Jul 19, 2004 | 09:04 AM
Tiago's Avatar
http://www.forcefedfab.com/images/PI...a/turbota.html
It runs insane. Im still testing it out as I go...1st, 2nd, 3rd, 4th gear traction limited, at 4 psi. First night out we had it at 12 psi and it was crazy, but too much without doing some tuning first.
I will be having it on a wideband to make sure whats going on with the fueling. AFter some bigger injectors and tuning the boost will go up.
Old Jul 20, 2004 | 10:02 AM
got_hp?'s Avatar
Re: My little turbo LS1....
very nice..........does the y pipe go under the cross member?
Old Jul 20, 2004 | 10:20 AM
Tiago's Avatar
yea it runs under the K member, no problem. After I have some fun with it I'll throw in a tubular K member and route everything above
Old Jul 21, 2004 | 12:50 AM
Reznor's Avatar
Insane!!
do you have any videos?
Old Jul 21, 2004 | 04:37 AM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
did you do this one the same way as the LT1 kit? Wasnt it BBK shorty headers with custon pipeing run to a turbo?
Old Jul 21, 2004 | 07:50 AM
Tiago's Avatar
similar, but I kept the stock manifolds here.
Old Jul 21, 2004 | 10:21 AM
DarkblueTA's Avatar
What system is this or is it a custom setup? Did you re-locate the battery to the back hatch area? Also, what kind of turbo(and size) and what kind of fuel pump/injectors are you going to be using?
Thanks.
Old Jul 21, 2004 | 08:24 PM
Tiago's Avatar
Yes the battery is in the spare tire compartment now.
The turbo is a custom Garrett T72, still running stock injectors. Only fuel upgrades are a Walbro intank pump and a FMU. I know I needd some bigger injectors so I can run more boost hehe
Old Jul 24, 2004 | 01:51 PM
Jesse_Boyer's Avatar
any chances of seeing some under shots? I'd like to see how you routed the exhaust
Old Jul 25, 2004 | 09:56 PM
Reznor's Avatar
the video sectionof your site doesn't work
i want to see this beast run
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
