LT1 Headlight Modification??
What are all the options out there as far as upgrading the headlights in our cars? A while ago I put silverstars in my stock housings, but one of them just burnt out, so I need to replace it. However, I didnt notice much of a lighting difference, other than the whiter light. So what else can I do? Ive heard of using higher wattage bulbs, but that if you go too high, you can burn out the stock wiring harness. Whats the deal with that? Thanks for any help!
Re: LT1 Headlight Modification??
I searched it, and found a few things, but nothing that is extremely helpful. One thing I did find was something about adding a 30amp relay. What is that? Where do you put it, where do you buy one, what does it do?
Also, does anyone have any experience with these bulbs?
HL88931S Replacement 9006 Bulb, 12V, 80W Optilux Xenon XB
Found that on www.rallylights.com, under the bulbs section. Thanks for any help!
use the info in this tread to get the upgrade harness so you can run higher wattage bulbs, and blackbowtie also lists a good bulb to buy
hope that helps
hope that helps
ChrisFrez
Feb 15, 2015 08:12 AM
Dec 4, 2014 11:56 AM
