Rim stains
What kind of rims? factory? custom? billet?
Are these the ones in question? http://evilbox.topcities.com/sde.jpg
Originally posted by EviLBoX
Sorry, forgot to add that. They are the stock 97-99 16" silver 5 stars.
Well, they are clear coated, so just use a mild polishing compound, I would use Turtle Wax Polishing Compound, comes in a little white tub, its cheap and should be rough enough to get the job done.
Do you keep the wheels waxed? Waxing and regular cleaning can help prevent this kind of thing usually.
I've never used the TW polish compound Kevin is referring to, but any good paint cleaner or swirl remover will likely work too. Something like Meguiar's Body Scrub, 3M SMR, etc...
Originally posted by CamaroPower
I have the same problem I, and I have the same wheels do I need to by a rubbing compound just for wheels or will like my swirl remover for my paint work for my wheels too.
Try what you have right now.
I used Rubbing Compound on the inside of my rims then I followed with Chrome and Metal Polish and it worked well. I don't know if I would use it on all of the outside b/c its pretty abrasive but maybe on a few small spots.
Mark
Mark
