GTO2Z28
07-14-2004, 09:33 AM
Got some parts painted, put them back on the car, and then took the car back to get the parts wet sanded. I noticed a couple days after I got it back that there were some scratches. I applied Z5, even though the 3m was suggested here, just to see what it would do to them. The spoiler looks fine, but the top part of the rear bumper, the part you could theoretically sit on, looks bad in certain light. It looks like it has horizontal scratches completely across the surface, and in a few places, up near the tail panel, there are places that look dull in certain light, kind of hazy like a smear. Will the 3m SMR w/ a 10 inch 2000 rpm buffer and foam pad take care of this? If so, do I need to remove the Zaino before doing this with alcohol/water? Thanks!
SSMOKEDU
07-14-2004, 09:51 AM
I've used 3M's 'Swirl Mark Remover', as well as their 'Swirl Mark Remover for Dark Colored Cars', after I've had Zaino on the car.
I don't believe you need to remove the Zaio prior to using the 3M product. If you choose to remove the Zaino though, you should use 'Dawn' liquid soap.
I've used the 3M by hand on some minor imperfections, and it has always worked well for me. I also make sure to apply Zaino to the area which was polished as a final step as the 3M contains "no wax".
Kevin V 2002 SS
07-14-2004, 11:54 AM
Dawn won't remove the Zaino. The 3M being an abrasive will remove any Zaino you have on the car.
Cmr0z28
07-14-2004, 01:54 PM
3M SMR is not going to remove sanding scratches...good luck.
slomarao
07-14-2004, 09:40 PM
A light compound will do it if it. You may have to do it more than once to get everything out. I would go back to the bodyshop and make them do it.
Cmr0z28
07-14-2004, 10:47 PM
^What he said. I wouldn't try to remove sanding scratches without the proper equipment/experience because it just isn't going to happen. Especially with a 10" orbital.
GTO2Z28
07-14-2004, 10:49 PM
I am going to call over there tomorrow to see when I can get the car back in.
GTO2Z28
07-14-2004, 11:27 PM
Here is a link, sorry for using another site---needed to attach, of the problem area:
http://www.ls1tech.com/forums/showthread.php?p=1551882#post1551882
Cmr0z28
07-15-2004, 12:27 AM
Listen to ZaneO, he knows what he's talking about. This is one of the reasons you should always pay in credit card.
