n2o for my 96
n2o for my 96
im wanting to put nitrous on my lt1, but i want to make sure the $5000 dollars i just invested into rebuilding the motor dosent go up in flames.. the motor has roughly 5k on it
my set up is pretty much as follows
stock crank
stock rods
30 over speed pro pistons
comp 305 cam
1.6rr intake
1.5 rr exhaust
ported maf
holly 52 mm tb
moroso cai
areomotive adj fuel pressure reg.
walbro 255 fuel pump
lt4 km
msd 6a
hooker lt's (no emissions)
mufflex off road pipe
cutout
and lt1 edit
can anyone tell me which setup will be the best for my this motor and what else i will need to buy
stock crank
stock rods
comp 305 cam
1.6rr intake
1.5 rr exhaust
ported maf
holly 52 mm tb
moroso cai
lt4 km
msd 6a
cutout
and lt1 edit
Re: n2o for my 96
How did you spend 5k on that setup?? Any way runing a window switch, low fuel pressure shut off switch and a wot switch should protect your new engine, i think you also want to run ngk tr6 plugs as well.
Guest
Posts: n/a
Re: n2o for my 96
No, not $100.00. I sent you an email but it must not have gone through.
I saw your post about wanting a nitrous kitfor your 355. I have a 1996 Z-28 that I have a complete TNT F-1 kit ($650 Retail) with NX bottle opener ($200.00), NX bottle warmer ($175.00), MSD Window switch, Fuel Pressure safety switch, Jimmy Jams WOT switch (the nicest you can buy, all worth about $130.00) and a Autometer Electric Nitrous pressure Gauge($210.00). It is all on my car but has only been tested and used on one dyno session. I am saving to build up a 355 Blower motor and of course am going with a blower instead of nitrous. I am going to remove the kit from my car and sell it. I will sell it all for $1000.00 firm if you are interested. This is verything to install and go. Let me know if you would be interested.
Thanks,
Ben
res7jyuw@verizon.net
Edit,
I forgot about the TNT purge kit. I will let it gor for $1100.00. I just removed the entire kit tonight. It is complete down to the switches but no wire, which can be purchased at and autoparts store. I have not posted this for sale yet, like I said, saw your post and just took it off.
Thanks,
Ben
Edit,
Guest
Posts: n/a
Re: n2o for my 96
Also,
This is the power that the kit made on my car with the mods listed below.
Dynojet results
Motor: 300.3RWHP 314.RWTQ
75 Shot: 343.2RWHP 379.5RWTQ
100 Shot 404.8RWHP 469.0RWTQ
150 Shot 443.7RWHP 514.2RWTQ
Black 1996 Z-28, 6spd with Pro 5.0 and Lou's Short Stick and MBA ****, K&N cold air, 52MM polished TB, Granatelli Mass Air Flow sensor with polished ends. Crane valve springs, Comp hardened push rods w/guide plates, Comp Pro Magnum roller rockers. Hooker ceramic coated long tubes with mufflex Y pipe, SLP Dual/Dual Cat back with Moroso Spiral Flow bullet in Intermediate Pipe. MSD 6A, MSD coil, MSD plug wires, NGK TR6 plugs. March underdrive pulleys. Auto meter electric Fuel pressure and nitrous pressure gauges in pod and Scanmaster. Granatelli 255lph in tank pump. Aeromotive adjustable fuel pressure regulator. 6AN braided fuel lines rerouted from factory location. DMS drop springs, BMR control arms, adj. panhard rod. Spohn weld-on lower control arm relocating brackets. Enkei Win wheels with 275/40/17's in front and 315/35/17's in back. Polished aluminum radiator cover, polished aluminum valve covers, polished aluminum Vortech elbow, chrome alternator, ceramic coated intake, ceramic coated water pump housing with Mezeire Electric water pump, ceramic coated accessories bracket and TNT F-1 nitrous kit with purge, NX bottle opener and NX bottle heater.
Dynojet results
