lovescamaros25
07-13-2004, 11:16 PM
whats faster in the 1/4 mile?A 2002 camaro ss or a 2003 mach 1 mustang.
which car is faster?lovescamaros25 07-13-2004, 11:16 PM whats faster in the 1/4 mile?A 2002 camaro ss or a 2003 mach 1 mustang. John1975 07-13-2004, 11:35 PM The ss, but anything can happen at the track. bombd84 07-14-2004, 12:49 AM last time I went to the track there was a stock mach 1 there running 14.0-14.3 It was 90* and 80* humidity. LT1ponykilla 07-14-2004, 10:36 AM The 02 SS would be faster. Especially on the street. Antz97ZNJ 07-14-2004, 12:46 PM The LS1 will normally trap more but there almost identical in the 1/4 mile TRICK95 07-14-2004, 02:56 PM Assuming it was an actual Mach I, it should be close, but once again, ya never know. They run pretty good from the factory. And I believe they're lighter than the fbody as well. Steve Y 07-14-2004, 08:27 PM The SS has a slight advantage, on the order of 2-3 carlengths in the 1/4 mile everything else being equal. ULTIMTEORANGESS 07-14-2004, 09:18 PM m6 ls1 is faster. until i see some conclusive proof im not sold on mach 1s hitting 12s STOCK. if you have any please show me.:cool: Steve Y 07-14-2004, 09:41 PM Originally posted by ULTIMTEORANGESS m6 ls1 is faster. until i see some conclusive proof im not sold on mach 1s hitting 12s STOCK. Exactly. Fastest stock Mach 1 by Evan Smith was a 13.1x at 105ish. He ran a 12.89 at 108ish in a bone stock LS1. It took Paul Svinicki DRs to get a very high 12 out of an otherwise stock Mach 1. ULTIMTEORANGESS 07-14-2004, 09:44 PM Originally posted by Steve Y Exactly. Fastest stock Mach 1 by Evan Smith was a 13.1x at 105ish. He ran a 12.89 at 108ish in a bone stock LS1. It took Paul Svinicki DRs to get a very high 12 out of an otherwise stock Mach 1. careful steve.you might cause an uproar. :lol: stereomandan 07-14-2004, 09:45 PM That's pretty dang impressive for either car. I agree that the LS1 has the slight advantage, although 108 mph trap vs 105 trap is a little more than a slight advantage. Dan Steve Y 07-14-2004, 10:10 PM Originally posted by stereomandan That's pretty dang impressive for either car. I agree that the LS1 has the slight advantage, although 108 mph trap vs 105 trap is a little more than a slight advantage. Dan Yes from high speeds the power and aerodynamics of the Camaro really shine. The Mach's gearing helps it in the lower speeds. Steve Y 07-14-2004, 10:12 PM Originally posted by ULTIMTEORANGESS careful steve.you might cause an uproar. :lol: Oh well, I can't help it if people can't handle the truth. :D Garbage 07-15-2004, 01:05 AM In the 1/4 they seem to be about even. LS1s and mach1s can both run low 13s. Its a drivers race. Why dont you ask this question on mach-1.org so you can get the other sides opinions. I bet every other post will be mach1 mach1 mach1 ;) 97bowtie 07-15-2004, 02:54 AM Originally posted by Garbage In the 1/4 they seem to be about even. LS1s and mach1s can both run low 13s. Its a drivers race. Why dont you ask this question on mach-1.org so you can get the other sides opinions. I bet every other post will be mach1 mach1 mach1 ;) Except the answers he got here are correct. ;) Steve Y 07-15-2004, 10:41 AM Originally posted by 97bowtie Except the answers he got here are correct. ;) Yep. Just because a lot of owners think their Machs are faster doesn't change the truth. Ricers think they can take Stangs and Camaros. Does that make it the truth? Not hardly. DocBowtie 07-17-2004, 11:50 AM And not opinions :eek: | ||
